bluwtr49's avatar
bluwtr49
Explorer II
Jun 23, 2013
Cat Oil Change Interval
I've been looking at different sources trying to determine the correct time to change oil on my Cat C-12 and so far have been unable to find anything that refers to the time between changes...it all relates to miles and fuel consumption. This seem to be in conflict with the "opinions" that state a yearly change is necessary.
For example, in an application less than 80,000 lbs, more than 7 mpg, and less than 20% idling time, the oil change interval is 25,000 miles. As MPG go down so does the interval. Oil analysis at 10,000 mile intervals with some discourse on what to look for in the results.
Cat Maintenance Schedule
So, unless there are some other Cat documents referring to a time between changes, what are most folks doing.
I sorta figure Cummins has a similar spec.
Clarity would be appreciated.
  • CAT recommendation for Rv is 1 year. Clean oil is a critical component to the engine. The cost is minimal compared to a filed HEIU, Injector or other component failure.
