Fer2005 wrote:
I'm looking to buy a DP and see a lot of negative press about the Cat diesels.  I haven't seen much positive press and there may be a reason for that.  Has anybody had a good experience with the Cat?
I've done the searches, may not be looking in the right spot.  Any good opinions would be great.  Thanks!
I'm not a big Cat guy, cause I cut teeth with Cummins in the trucking industry.  The only negative press about Cat that I know of is the fact that they are getting out of building and servicing over the road engines.  But then I remember when they started building over the road engines.  Their engines were noted for major hill climbing torque when pulling heavy loads.  But when they started building over the road engines, you had to go to a construction site to find a mechanic to get them worked on, cause there were no Cat mechanics to be found in heavy truck garages.  Today there are all kinds of Cat mechanics out there.  Would I buy a motorhome with a Cat???  No, but only cause I know my way around the Cummins diesels, and not Cat diesels.  It is kind of like the Ford pickup Chevy pickup thing.
