jrp wrote:
If you gather your input from internet forums, you only hear the bad stories. The thousands of Folks who are happy with no problems don't feel the need to go post on a forum.
I have a 2005 C7 that's been flawless and very reliable. There were a few initial issues mainly caused by Freightliner the chassis builder, but were easily worked out.
Fer2005 wrote:
I guess most of the problems have been with the mid-2000 models, C7 and others.  Most of the complaints have been with the fans seizing, fuel pumps going bad, blown head gaskets and other problems.
I haven't seen any problems on earlier models and very few people have posted as Dolan did, no problems.
Just wondering if it was a short period where the problems came from and then the problems were fixed.  Thanks again.
That's pretty much the norm!
People will write and talk about "issues" way more than just coming out and posting, "man, we've got a 20xx series CAT and it's been working flawlessly for all the time we've owned it."  I am not an expert on Diesels but, have been driving them for my entire career in Fire Department related use. We've had CATs, Cummins, Detroits, and even a few Internationals. While each has worked for us over the years, we chose as a base engine for the last 15+ years, the Detroit series 60.
But, in motor home use, if anyone who's been into any research of the diesels used in them for the last few years has found out that, both Cummins and CAT has had issues. Certain models of Cummins have had and, maybe still are for all I know, "Wrist  Pin" issues. And, from what I've read and heard, the remedy for that is not pretty in the eyes of the present owners.
 And as for CAT, yes the C-7 has had some issues. Namely the HEUI pump. Hydraulic Electronic Unit Injector pump. When it decides to go south for the winter, it takes the injectors with it. That, as an average, is pretty close to about a $6500.00-$7,000.00 repair. The predecessor is the 3126 Series CATs and, seem to have a tad bit better durability/longevity record for CAT than the C-7. But, that's  not to say the C-7 is a bad engine. There's only a few hundred thousand of them still running flawlessly in not only motor homes but dump trucks, delivery trucks, some over the road trucks and more.
So, while CAT decided to pull out of the "On the road" diesel market a few years back, I'd not hesitate to own another CAT engine. We presently have an '04 Itasca Horizon 36GD with the C-7 330 CAT. I'm not too fond of the non-lube fan bearing but, it is what it is and, so far, it's doing just fine. About the only thing I like better about the Cummins than the CAT is, HP for HP, the Cummins has a higher torque rating.
Scott
