MountainAir05 wrote:
should not be hard, if fiberglass then you will need a ground wire to the antenna. I have installed one on every RV we have own. All worked. You just have to pick a place usually drivers side front and look where to get cable if not already ran and the antenna mount.
How I'd do it.
First get a good (Firestick?) NO GROUND PLANE antenna.
now on the "A" pillar (First pillar the one adjoining the windsheld) Id' find a mount so the tip of the FireStick is 1" higher than the highest point on the RF (I like double purpose. that makes it a "Bridge Stick"
Use half a "Mirror mount" (The L shaped half)
Drill and pass the coax into the pillar under the mount. seal with GOOP (you do not want leaks) mount with lag bolts.
Down the pillar to under the dash. From there all you need to do is decide where to put the radio...
How I did it and a warning
I finished and lag bolted a 2x4 to the wall, Left of the Driver's seat UNDER (Warning) the windo.. Mounted radio's (3 of 'em) to the 2x4
WARNING.. Window sweats. water got into one of the radios.
But there are other places you can mount.
GALS or GALLS (Police equpment) sells some interesting mounts.
