falconbrother
Dec 16, 2014Explorer II
Mine has a steel or metal framework. If you find the ribs you can drill a small hole, enough to feed a screw or however many you need. The sag could be caused by a leak or may not. Usually if it's a leak you will see something to let you know that, be it stains, water pooling, mold or mildew or something. I did a couple of ceiling ribs a couple of weeks ago that were starting to come down a little. I used small button head screws and then painted the heads to match the ceiling. Unless you were looking for it it's not likely you would see it, or care. The important thing when putting screws in like this is that if there are several they need to be in a straight line.
38,769 PostsLatest Activity: Jul 09, 2020
