- jhilleyExplorer
crasster wrote:
I always replace custom RV stuff with stuff from Home Depot. Every time you go custom it will be $$$$ Now the place may be reasonable for replacement, but if you smell a ripoff for plastic covers, I'd go HD or Lowes.
Not much in 12 volt lighting at Lowes or other big box stores. When I look to replace things in an RV, I look at marine equivalents, usually much better quality. The Thin-lite fixtures are good lights, especially so if the fluorescent tubes are replaced with LED tubes or strips. - crassterExplorer III always replace custom RV stuff with stuff from Home Depot. Every time you go custom it will be $$$$ Now the place may be reasonable for replacement, but if you smell a ripoff for plastic covers, I'd go HD or Lowes.
- jhilleyExplorerThey are available from John Drake
- xctravelerExplorerIt may be cheaper to just replace the fixtures. Last i looked they were less than $10. Change them for LED fixtures in the same form factor and they will cost more, but you can forget about servicing them and your batteries will love you.
