ricelake922's avatar
ricelake922
Challenges replacing the wallpaper
I had some water damage to the bedroom and removed all the wallpaper. I sprayed the walls with mold deterrent, sandpapered and then primed with oil primer. I purchased wallpaper that could be painted. The wallpaper will not stick to the walls. Place I bought the wallpaper from say I should use glue. Don't really want to do that as I am working in a small space. I am thinking of just painting the walls but will have to use alot of filler as some of the wall wood peeled off. Any ideas or suggestions would be appreciated. Thank you in advance.
  • If you're concerned about the glue fumes, use a vent fan in a window.
