rgatijnet1 wrote:
dan-nickie wrote:
I would say unplug the RV ande turn generator off to be sure.
And turn off the inverter, which is still going to produce 120 volt power from the batteries.
Switching off the main breaker does turn off power to that breaker BUT, you have to remove the panel cover to pull the breaker. Once you pull the cover off of the panel, even with the main breaker turned off, there is still points that you can touch that have power. Better to stop power from getting into the panel than to trust that you will not touch anything that is hot with your hand or screw driver.
True but the chance of the Op touching the live area on the hot side of the 50amp breaker are very unlikely but its good to make him aware because as u said hes never done this sort of thing before
