fcooper
Dec 19, 2015Explorer II
From Freightliner Service Bulletin 54-12
Fred
Freightliner wrote:
Odometer and Trip Odometer (Note MC means message center)
The MC is equipped with a speedometer and a tachometer. A digital odometer display is located in the speedometer
and a digital trip odometer display is located in the tachometer.Both odometers can display either English or metric values (miles or kilometers). A trip reset switch is located
on the lower right corner of the dash panel. If the switch is depressed for more than 4 seconds, both displays
will cycle between English and metric. At the left sides of the odometer displays, a triangle will point to either an
"m" or a "k," depending on which scale is selected.
To reset the trip odometer, depress the switch for less than 4 seconds. The odometer resets to either 0 miles or
0 kilometers. The display indicates in 1/10 (mile or kilometer) increments, depending on the scale selected.
Fred
38,782 PostsLatest Activity: Sep 10, 2026
