LaTriker's avatar
LaTriker
Changing Tires
I am currently running Goodyear G670 275/80R/22.5 tires on my MH. I plan to replace them with Toyo tires. The problem is that Toyo does not sell that size. Does anyone know the best replacement size for the G670?
  • DaveG39 wrote:
    I have been using Goodyear for years on multiple RV's with no problems. What do you find to be the problem with them?
    Goodyear engineers say it's rivering (also called erosion)
    I had this problem with about 18k miles, switched to Michelin 295 80R22.5, no problems now.
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24564989/print/true.cfm
    JR
  • I have been using Goodyear for years on multiple RV's with no problems. What do you find to be the problem with them?
  • Corkey05 wrote:
    I changed over from the Goodyear G670 275/80-22.5 to the Toyo 295/75-22.5. The difference is so small you won't notice, almost identical in dimensions. I've found little difference, but make sure you go for the M-154 in load range H.
    Here's a profile overlay of the differences along with the numbers.
    Click Here to View
    Why do you specifically recommend the M-154? Is it better than the M-144?
  • For RV's I always prefer Hankook. I think they have a great wear life, are quiet, and good on price.
  • I changed over from the Goodyear G670 275/80-22.5 to the Toyo 295/75-22.5. The difference is so small you won't notice, almost identical in dimensions. I've found little difference, but make sure you go for the M-154 in load range H.
    Click Here to View
