enblethen wrote:
Verify that you have a transfer switch or whether you must plug the genset into a receptacle in the shore power cord compartment.
If equipped with transfer switch or if you must plug into a receptacle, the converter should charge the batteries.
That is if you are in deed talking house batteries and not chassis battery.
I was just going to suggest this. My old gasser which actually was newer than the DP I have now did not have a transfer switch and the power cord had to be plugged into a receptacle in the compartment the power cord goes in. My converter was also in that compartment. Needless to say it did not take me long to put a transfer switch with a built in surge protector in that compartment.
