coolmom42's avatar
coolmom42
Explorer II
Jun 26, 2014
Charging house battery from alternator---disconnect switch??
I saw a post (either here or in the Class B section) about exactly how to wire a house battery to charge off the alternator. The description included directions on how to wire a switch to disconnect the house battery from the chassis battery, so as not to run down the chassis battery. But then the switch can be turned to charge the house battery from the alternator while driving.
But now I can't find the thread. Can't turn up anything on a search.
Can anyone help me find this thread, or at least one with similar info?
  • wwest wrote:
    My class C has a relay that couples the engine charging system to the house battery ONLY when the alternator is powering the rotor winding internally.
    In other words it requires alternator output to connect the two systems? Is this a typical wiring scheme, rather than ignition on to connect the batteries?
    Reason I ask is in alternator failure scenario I am hoping to run generator and back power the engine from the power converter.
  • JaxDad's avatar
    JaxDad
    Explorer III
    The simple solution is to use a constant-duty rated solenoid. Run a fused wire from the alternator to the solenoid and then on to the house battery. Use a 12 volt source from the ignition, there's usually a spare or two beyond the one for the radio, etc., to put power to the trigger terminal of the relay.
  • rich85704 wrote:
    Wait -- doesn't the house battery *usually* charge off the alternator when driving? I'm confused.
    R
    Yes.
    But in a retro-fitted camper van--which I am thinking about doing--there needs to be a switch to isolate the house battery during use so as not to drain the chassis battery accidentally.
  • My class C has a relay that couples the engine charging system to the house battery ONLY when the alternator is powering the rotor winding internally.
  • Hi,
    Yes, in a class C. But the OP is not in one.
    R
  • Wait -- doesn't the house battery *usually* charge off the alternator when driving? I'm confused.
    R
  • Hi,
    You can add manual control to the relay as well. Any continuous duty solenoid can be used--mine are rated at 100 amps each but circuit breakered at 50 amps. I don't wish to have burned contacts in the relays.
  • Hi,
    It is really easy to install what you want. Take a #8 wire and connect to your alternator, then to a 30 amp capacity fog light relay, then to a 40 amp automatic reset circuit breaker. Then to your second battery.
    That will do it.
    Fred.
