FIRE_UP
Jul 26, 2014Explorer
flapbreaker wrote:
I had some over heating issues while towing in 85 degree weather up hills recently. I've never heard my clutch fan kick in so I am replacing that and also the thermostat (it opens but a new one opens a bit more when I compared the two). Anyway, I know it's important to keep proper airflow through the radiator. While looking around it appears that I have a large A/C condenser that sits right in front of the radiator. The condenser has very thin blades with very tiny spaces. Much smaller than the radiators spaces. Also, in front of that sit's another cooler of some sort. I feel like the A/C condenser would have to reduce airflow through the radiator. Are there different condensers that would allow better airflow or should I not worry about it?
flapbreaker,
A few things here before you zoom off to your local auto parts store and start wasting money. First, A/C condensers have been placed in front of radiators since the beginning of time and, for the most part, have never caused any heating conditions. The manufacturers have calculated all this out, including all air flow with, and without fan clutches. So, without being there and helping you with this issue, I'd say your A/C condenser is not hindering your cooling system what so ever.
Second, I had the almost exact same unit that you have now, in our last coach. It was a '99 Fleetwood Bounder, 34V with the F-53 chassis and the V-10. That unit ran flawless for the full seven years we kept it. It never moved an inch, without towing something. We ran the trip from San Diego to Moab Utah for the Easter Jeep Safari, for fourteen years straight and not one over heat condition ever popped up. We also had the earlier version, a 28' Class C with the 460 and it too, ran great without any heating issues.
Third, fan clutches are great inventions. When working as designed, they give additional power to the engine, when not needed and, under certain working conditions. About 99.9% of the time, on a cold start, the fan clutch will go to almost full lockup, due to its programming. But, if you were to drive off, when the engine is still dead cold, you'd really hear the thing for the first few hundred feet. Then, miraculously, it goes instantly silent. When operating our Bounder and driving away from our home, it could plan the exact spot in the next block, when the clutch would go silent.
So, one point here is, before you go buy either the factory fan clutch, which, are you sitting down, is right at $140.00 or, an "el cheapo" at your local Auto Zone, which is around $49.00 and, you really get what you pay for here, make sure your fan clutch is in fact, DEAD! Many fan clutches, when dying, will "Lock up" to a full 100% and stay that way. Not all, but many. I'm not saying your fan clutch isn't bad, it very well may be. I'm just suggesting you do some tests before tossing an expensive part.
Fourth, you don't say what exact coach you have, the mileage, how long you've owned it and, what, if any, maintenance has been done on the cooling system. The lower radiator hose can cause the same heating issues you spoke of because the spring, inside it, has either disappeared, rusted, collapsed, or ? You've dug into the thermostat and tested it and found it works but, you're thinking of replacing it with another one and, that's fine, it's not much of an expenditure.
You say you had a "heating issue". May I ask, what exactly do you mean? Did it boil out? Or, did the needle on the gage just climb up into an area that it normally doesn't go to? Another thing. If you have one of those infra-red heat temp guns, (you can get them in many places), you can start your engine up, and keep shooting that gun at the thermostat housing, top and bottom, to see at what temp, the thermostat opens, when operating the engine during warm up.
And finally, you can do a flow test. Leave the cap off the radiator and start the beast up. The coolant will just sit there while in the warm up stage. But, when the thermostat opens, you'll see an instant flow if, the water pump is functioning appropriately. Then, it will come to an abrupt stop because the thermostat closed again. If all that is well, then you should have a clear set of tubes in the radiator. You can also see, during hard revving, the collapse of that lower hose, if the spring is missing. That would cut off the coolant supply during hard acceleration or, hill/grade climbing. Not good.
Anyway, hope you get this situation remedied without ruining your A/C system. Good luck.
Scott
38,769 PostsLatest Activity: Mar 31, 2026
