JaxDad
Nov 19, 2021Explorer III
A great diagnostic trick is to remove the negative terminal from the battery then put an incandescent light bulb like an 1156 on jumper cables in between the negative battery post and negative cable.
If there is a load, path to positive, the bulb will begin to glow.
Then opening connections one by one will show you the culprit when the light goes out.
38,782 PostsLatest Activity: Sep 20, 2026
