luggnutts
Aug 06, 2015Explorer
check valve!!
I have a 1999 rexhall 32 ft rexaire. While camping last weekend, a secutity person informed me I had a water leak ( california drought). At night couldn't find source, turned off water till morning. I...
Old-Biscuit wrote:luvlabs wrote:
Let's see if I've got this right. You are hooked up to city water and your water tank has filled itself and is now overflowing. Is this correct?
If this is what is happening the most like cause is the check valve in the water pump. Lot's of things can cause this to happen - incoming water pressure is high and is forcing water past the valve, a bit of dirt has caused the valve to stick open, or maybe the valve has just worn out. Fixes are relatively simple - add a check valve between the tank and the pump inlet, rebuild the pump, or replace the pump.
Ding, ding, ding........
Pump has an internal check valve and city water connection has a check
valve. They are there so city water doesn't backflow thru pump and fill/overflow fresh water tank and so pump when running doesn't leak out city water connection.......both feed same plumbing system
Simple/basic RV plumbing system
