mike brez wrote:
No. Springs may be shot. When I needed new bags on mine I ordered new springs from Henderson super steer and ditched the bags. The springs are matched up to your front end weight.
Some good reading for the P30 Here
Also when you inflated the bags I believe the proper way is to lift the front end up then inflate and lower onto ground. I would put 90lbs in mine lower and bleed off.
Yep, OEM spring fatigue and no air bag will fix it for the proper ride height, so it can be properly aligned. They don't last, but for a few years anyway and was always sorry I didn't do the after market Henderson thing in the very first place, with our old coach.
