bjarnold wrote:
I had the suspension checked when they did the air bags and the springs were fine. The only issue they found and replaced was the sway bar bushings on the passenger side
Again, air bags are a waste of time and money, if you're going to keep the coach for any length of time. Not only that, you'll need to be constantly checking them for air while traveling and eventually you'll find yourself with one that won't hold air. Might as well let the air out of the other one now and until you can do something with it.
As said, there has to be 1.75 - 2.50" of ride height between the stops and and the upper control arms to properly align it.
