snowdance
Sep 11, 2012Explorer
My 2000 Chevy has rear leaf Springs. My rear springs are not curved high in the center like the Fords I have seen (Have not seen them all) but a normal spring stack and leafs are near flat. It was made by the Mor-Ride company as all the Chevys that were done by Fleetwood then and has thick teflon pads between the springs. So they move easy. I also went with a softer shock so using Monrow shocks. Mine does ride far better in the front and rear than the 3 Fords I have been in. But with some work I am sure the Fords could be fixed.. I also have heavy sway bars as 25 to 50 mph winds are common here and most of the roads I run have no sholders just a drop off often 10 feet or more. So go for every advantage I can get..
38,780 PostsLatest Activity: Jul 04, 2015
