IAMICHABOD
Dec 28, 2015Explorer III
coolmom42 wrote:
Good job on the preventive maintenance. An investment that will save you some $$ and hassle down the road, for sure.
What did the mechanic do to the fuel injection system? Just curious.
A chemical is introduced into the throttle body that will clean out the carbon in it and
deposits accumulated on intake valves, injectors, ports, fuel injectors and combustion chambers causing loss of power, rough idle and correct balance of fuel and air in system.
Allowing for better fuel flow into the combustion chamber, which will get better fuel mileage and reduced emissions.
This was done at about the 50000 mile mark so I thought it was time to have it done again.It is just good preventive maintenance.
It does run better with better acceleration and fuel mileage.
