DrewE
Feb 08, 2018Explorer III
Quite a variation of opinion here!
I'm guessing you could maintain 70 or more on level ground, but almost certainly will slow down on anything much more than a minor uphill grade. You'll likely find that true to varying extents with most any class C. I don't have specific experience with the Chevy 350 in a motorhome, though.
Don't expect to make time like you can in a car or SUV in any motorhome. To be safe, you need to leave yourself a lot more room to accelerate, brake, and turn than in a smaller vehicle, and that means goinlg at least a bit more slowly and less aggressively. I avoid passing other vehicles unless they're going a lot slower than I would go; judging passes for a long vehicle is a bit tricky, especially if one has limited experience in doing so, and it takes a fair bit of time and space to accelerate past another vehicle at highway speeds.
The LT tires typically used on class C motorhomes are usually not rated for use above 75 mph.
38,780 PostsLatest Activity: Aug 05, 2026
