Follow this order:
check for spark at the spark plug, look at your dist cap and rotor. make sure the cap is tight, but don't break the plastic distributor base if it has one. If no spark then look at ign module, cam sensor, coil in that order.
If spark then it is fuel. Check your fuel pressure, check your fuel filter, take it off see if there is anything in it. If it is clear, then reinstall and listen for fuel pump sound when assistant turns on key. No sound then fuel pump. test fuel pump in tank with 12v.
