Kerri's avatar
Kerri
Chinook 1997 questions
I have a Chinook 1997. We are planning on dry camping for a few days. I don't understand how to get my water tanks clean and ready to haul some.
In my Jayco toyhauler I use bleach. But I was told not to do that with this camper.
Thank you for helping
Kerri
  • Like many other rv owners I use pool shock to clean my fresh water tank...about 2 tablespoons of dry powder to a full 30 gallon tank.
    a bag of pool shock powder is a few dollars at the pools store or home depot
    I'll leave this in the tank for a couple of days and let it slosh around while I go get the tire pressure checked ( costco) and get supplies...put a few miles on it.
    I'll then run all the taps and move this through the systems.
    after this I fully fill and flush the fresh water tank with city water.
    works fine
    http://rvbasics.com/techtips/sanitizing-your-rv-fresh-water-system.html
    like "bleach" this is corrosive so handle with care- I do carry a plastic container with powder in the van, easier than carrying liquid bleach
    mike
  • They said not all fresh water tanks are the same. I looked all over to find out why, but can't find anything.
    They are all made from plastic. So I'll clean with bleach and water.
    Thank you
    Kerri
    Kerri
    Someone gave you a line of bull.....Go ahead and used the bleach water solution
  • Is your Chinook based on a van chassis, Class B, or a cut-away Class C. If it's a Chinook Class C you might get a better response in the C forum.
