enblethen wrote:
I would not use a switch. A momentary double pole double throw to (to reverse polarity) switch would work but rating should  be rated a minimum 20 amp, 30-40 amp would be better.
Have you checked Ebay for upgrade kit? Or other parts.
After replacing circuit breaker, check operation.
Another common problem is the TWO ground connections for the step.
Checked and cleaned all ground cables and positive cables first thing.
Yes found some on ebay and Etrailer has them.about same price and much better priced.
Will have to figure out what to do now.
Thanks much!
Dad
