Dr_Quick's avatar
Dr_Quick
Explorer II
Sep 28, 2022
Class ‘A’ motor homes FORD chassis.
If you own or are thinking to buy a Motor Home with a Ford Chassis, or you have just purchased one, you need to read this.
A friend of mine bought a new Jayco Class ‘A’ Motor Home in mid year 2020.
Recently while on a trip the right front wheel bearings went out, and he came very close to a catastrophic accident as the tire was just second away from blowing while he was driving on the interstate. Vehicle only had 20,000 miles on it.
He was about 60 miles form home when this happen. The Ford truck repair dealer closest to beak down refused to even look at the vehicle. It took him 26 hours to find a place to tow vehicle to have repairs done.
So since the Motor Home is only 2 years old it should be under warranty. But here is the problem. Since Ford sold the chassis to Jaycee mid hear 2019 that is when the warranty started. Not when Motor Home was purchased. Cost to have repairs done was around $7.000. So Ford says they are not responsible as it is out of warranty. The Ford owners manual requires wheel bearing repack at every 60,000 miles. So this should fall under being a factory defect. It could only be one of three things caused the problem. Insufficient greasing at time of manufacturer, bearing was installed too tight, or a defective bearing. Which lays problem completely at Ford.
I also wonder if this problem would apply to all Class A?
