wolfe10 wrote:
My point is that ANY shock that is valved to control sway will be WAY TOO STIFF for all other conditions. Said another way, do not expect shocks to control sway. That is the job of sway bars, with any shock, even the best only contributing a small amount.
Exactly. Shocks may help in a dynamic sway situation (rolling back and forth multiple times) but you need to limit the level of roll in the first place by increasing the "roll stiffness" of the chassis, and that is done through adding "anti-roll" or "sway" bars.
We have a WH chassis so not the same comparison for an F53, but I added Hellwig bars both front and rear before a two week summer trip through the east coast mountains and it made a significant difference. Example: entering a gas station at an angle where the curb cut-in to the main road usually would send the MH into an oscillating back and forth motion and make everyone sick and throw belonging everywhere. I used to need to enter very slow, now I can enter more like I'm driving our truck.
This has a direct impact on driving down curvy roads - less body roll as you enter corners means more confidence and less white knuckle. I would not have done the trip without them - pricey but worth it, especially since we are going to Utah this summer.
In general, as I understand, the upgrade paths are:
- Sway bars for body roll (control on curvy roads)
- Track bars for passing trucks, high winds on the interstate
- Steering stabilizer for consistent high winds and also helps with passing vehicles
- Shock upgrades for poor ride and chassis control on rough roads
Our coach has all of the above - each has it's own primary effect, but having them all can improve upon each of the individual upgrades. For example sways + shocks will have more roll control than just sways, but sways are what you want first for that.
Anyone please correct where I may be incorrect in the above.
Now I drive a coach that I would argue "should have come from the factory like that"
