Kidoo wrote:
Dutch_12078 wrote:
I'm guessing that most of you have never pulled the axles and hubs on a full floating Dana rear axle. Or removed/replaced the rotors.
Do you have to remove the axle to replace the rotors? Are the brake pads straight foward like similar brake system?
The brake pads/calipers are pretty much the same as on cars, just bigger and heavier. And yes, you do have to remove the axles and hubs in order to remove/replace the rotors. The rotors are bolted to the back of the hub at all wheel positions. No nice easy slip on rotors on an F53.
