wolfe10
Sep 22, 2015Explorer
Koop wrote:RFCN2 wrote:
I believe Entegra still puts a custom chassis under some of their models. And I think Tiffin puts the Peak chassis under a few of their coaches which is a custom chassis.
The Peak chassis was designed by Gary Jones and made by Western RV exclusively for Alpine Coach. Tiffin has their own chassis available - it's called a Powerglide and shares some of the Peak features.
CORRECT. Gary Jones had his hand in the design of both. Similarities but not the same.
Having an Alpine, I can tell you that there are a few features that DO make this the BMW of motorhomes:
Very long Wheel Base to Overall Length ratio: our 38' Alpine is on a 262" wheelbase.
Four, not three ride height valves-- air is NOT transfered from the outer wheel position to inner wheel position rounding corners/it corners flatter.
Larger engines: ISL 400 HP/1,200 lb-ft torque on 26,250 pound (loaded) coach.
Side radiator-- better cooling, less HP drain under non-excessive heat conditions.
38,782 PostsLatest Activity: Sep 10, 2026
