noswad's avatar
noswad
Class A diesel help
Hello, I have a 2001 Damon Ultrasport with a 24 valve 5.9 ISB. I have run into a problem. When driving home from the campground sunday it was raining. I had the generator running so the kids could watch TV. Every so often the check engine light would come on and the tach would get real jumpy and I would loose power. If I was pulling a hill then it would not downshift. Then the light would go out and the power was back. No other gauges would be affected. So then I turned the generator off and the check engine light would not come on. In my regular maint. I changed all filters, oil and etc. Even the generator fuel filter. which was less than 150 miles ago. Does anybody have any clue what this could be??? Maybe a ground wire loose? Fuse?? Please let me know what you think I should check.
Thanks, Chris
