Fifty4F100 wrote:
tropical36 wrote:
Fifty4F100 wrote:
tropical36 wrote:
Dutch Dolly wrote:
My husband and I are looking at buying a used motorhome (probably around 2004-2005) and were told by a mechanic friend of ours to stay away from the Ford Triton V10 engine. But it seems like everything I look at has this type of engine. What can anyone tell me about this engine and can you suggest other models that have different engines? I did see a 2005 Damon Challenger that has a GM 8.1L engine. Does anyone know anything about this type of engine?
That's ridiculous and you can tell your mechanic I said so, although I wouldn't want one of the first V10's about 1999 or so and feel that they were somewhat underpowered. Now having said all that, I would probably go for a nice Workhorse W chassis, while I could still get one, in that year model with the GM 8.1 and especially with getting an Allison transmission that comes with it. Be sure that the brake recall has been done on all but the W24 chassis, which didn't require it and you should be good to go after a close inspection.
I'm also partial to National products and especially the Dolphin model in those years, while you can still find one of them, except some have basement air, that I would rather not have, so there you have MHO on the subject and for whatever it's worth.
I have the 99 6.8 V10 in a 36' Holiday Rambler. It tows my PT Cruiser ok. The main problem I've had is once in a hard rainstorm. The early Ford F53 chassis had an air inlet that was too close to the road and could suck water into the filer, colapsing it and starving the engine for air. I'm guessing you know how I know this. Now I travel with a spare filter until I can find/make a fix for it.
Not to run down the GM Workhorse chassis, but I've never seen one for sale in my area. I don't know why they quit making them, but I know GM didn't have that engine very long.
There's a story about Workhorse and when they were taken over by their new parent company and what it entailed. As for GM's big block, there's a kazillion of them out there in different forms and vehicles and probably beginning with the 396 cu in back in 1965, which evolved into the 427, then the 454 and later adding fuel injection and going metric with the 7.4 liter. Many a coach on the road are running this engine which includes the later 8.1 and nothing more than a little more stroke over the 7.4. GM had to make a lot of economic decisions as part of their chapter 7 some years back and the reasons go much further for the demise of the beloved big block Chevy.
I was of the opinion that the 8.1 in the Workhorse chassis was of the new Vortec design GM has used since 1999. Not the old big block Chevy.
As per say, you're probably right, since the Vortec was when they went metric (7.4 liter = 454 cu in) and with fuel injection, but the block casting itself, I think has pretty much remained the same for a very long time, now....
Big Block ChevyAnyway, they're very wide spread from the corvette to cars to trucks to motorhomes and boats as well.
Ford dropped it's big block 460 cu in V8 back in 1998, so there's no way that the present and smaller V10 has had such widespread use. That being said, the V10 is an excellent engine, but has to crank out more rpm's as a substitute for it's lack of cubes and once one gets used to the screaming, they should like this little engine (6.8 liter) very much so.
