blazenpm's avatar
blazenpm
Class A opportunity
I am looking at a 34 ft. Class A Bounder 2007 with two slides. The bedroom has a King size bed. The outside condition is pristine. The inside reflects the outside in condition. It appears to have been given very good care. The retracting two step entry needs attention. The generator also needs to have a hose replaced. It has 11,700 miles on the odometer. They are asking 45 K. Is that a good price?
  • If the floor plan fits your intended use and you did not have to compromise on too many must have items I would think the price is reasonable.
    Mileage shows very limited use so there are a few chassis related items to check. Maintenance records are a big up check if available. Basing maintenance only on miles isn't always best. It should be on it's second set of tires so check the tire date codes on the side walls. If you are a confident DIY type or shade tree mechanic the steps and generator repairs are not difficult.
    Got any images of the coach or an on line listing?
