jwoodie wrote:
lbligh wrote:
jwoodie wrote:
Does anybody here believe that 5,000 or 10,000 pound tow ratings are the result of an exact mathematical calculation? These are obviously general guidelines with a built in fudge factor. Otherwise, slight variations during the manufacturing process would result in some failures even when below the "maximum tow rating."
I am not suggesting that these rating be ignored, only that they be taken with a grain of salt when evaluating the towing capability of your rig. For example, dead tongue weight, weight distributing and four-down towing hitches are drastically different towing propositions, as are terrain, elevation, braking capacity and driver experience.
That being said, I would not greatly exceed the specified ratings for fear of voiding warranty and/or insurance coverage.
Indeed a lot of engineering and "exact mathematical calculation" goes into rating capacities including GCWR. Statements like "these are obviously general guidelines with a built in fudge factor" sound ridiculous. Folks that run around and ignore ratings sure make a good argument to require CDL licensing standards to all motorhomes.
Now... if someone would like to see a good snapshot of just how ratings can change depending on various factors (axle capacities etc.) take a few minutes and visit the link below. A very good condensed piece of information to educate some who may want to learn something. The detailed specification information starts on page six of the file. While these specifications are for the 2014 Ford F53 chassis, the same kind of engineering goes into any motorhome chassis or commercial vehicle.
https://www.fleet.ford.com/resources/ford/general/pdf/brochures/Class_A_brochure-2014_LoRes.pdf
Safe travels.
Amazing how these mathematical calculations come out to exactly 5,000 or 10,000 pounds. Statistically impossible, of course.
I am not sure if you have a problem with math/numbers or reading or possibly both? Or maybe you didn't even bother to look at the documents or possibly don't understand them? Out of the six examples shown, only one came in with a 5,000 lb number. None had 10,000 lbs. In fact, the range was 4,000 lbs to 7,000 lbs. Maybe you need to look again?
Safe travels.
