seedhay wrote:
I don’t know if this is the place for this question. I am a year away from upgrading from class C Ford 29 ft to 31 to 35 foot class A. The new Ford A chassis should be out by then with the bigger engine and 10 speed trans. My first question is the bigger engine going to be a V 10? Second is opinion from current owners that have had both 19.5 and 22.5 tires. I am excavating contractor and have always gone with biggest wheels possible. Problem I have is most 32 footers are 19.5 rubber ( but is my preferred size for coach. Or the 35’s with the 22.5
Thanks in advance for you opinions
Seedhay
I have 19.5 tires on a 33 foot motorhome with 2 slide outs and never a issue with the tires, as to weight carrying also no issue, my 6 tires carry more weight than the 20,500 lb chassis does.
Also a plus for 19.5 is you can carry a full mounted spare and they cost less..
