Francesca_Knowl
Sep 25, 2014Explorer
dodge guy wrote:Rollnhome wrote:
Arizona Revised Statutes (ARS) 28-5708 imposes the use fuel tax on light class motor vehicles as defined under ARS 28-5701 and on exempt vehicles pursuant to ARS 28-5432.
“Light Class Motor Vehicles” are defined as any motor vehicles using use fuel (diesel) on the highways of this state except for use class vehicles. Use class vehicles include a road tractor, a truck tractor, a truck, having a declared gross vehicle weight of more than 26,000 pounds or having more than two axles or a passenger carrying motor vehicle designed to seat more than 20 occupants."
This is copied from the state law. I read it as two axle MH over 26K are classified as Light Class Motor Vehicles.
Yep! and therefore are not required to pay the higher tax!
Dunno where exactly the above is copied from, but a more appropriate reference is the definition of "use class vehicle", which clearly reads:
AZ 28-5601 wrote:Note:
37. "Use class motor vehicle" means a motor vehicle that uses use fuel on a highway in this state and that is a road tractor, truck tractor, truck or passenger carrying vehicle having a declared gross vehicle weight of more than twenty-six thousand pounds or having more than two axles.
"Use fuel" is diesel. And I'd note that BOTH do refer to the more-than-two axle thing.
Copied directly from the Statute as published by the Az. Legislature at this link
38,769 PostsLatest Activity: Dec 31, 2014
