RayChez
Sep 26, 2014Explorer
I guess it pertains only to commercial vehicles because just about every diesel longer then 36' weigh's more then 26,000 and that is with two axles. Mine is only 38'and it weigh's 30K. So if it pertains to everybody commercial or none, who determines what the coach weigh's when you pull into a gas station. Some coaches will vary considerably in weight even though they are the same length.
I do remember seeing the stick on the fuel pump and it did say something about the weight of the coach, but I do not remember reading anything pertaining only to commercial vehicles.
I will be going to Laughlin for a Gulf Stream rally Oct 25. So I will check it out. We sure do not want a $1000. fine. I would be so mad I probably would say some choice words to governor Brewer.
38,769 PostsLatest Activity: Dec 31, 2014
