kemer
Jan 22, 2015Explorer
Class B - B+
I see some sales categories listing Class B and Class B+. What is the difference? Is a B+ a bit larger/longer?
BudJ wrote:
"How many forum inches have been filled up with this ever recurring subject?"
752
Bud
My Roadtrek wrote:
RIVA does not recognize a B+ as a Type of RV. It is a made up manufactures term for a small Class C.
A Class B started out as a van, after that it doesn't matter what is done to it.A "Type" of RV is based on what the original chassis is, not what the body was altered to look like.
This is RIVA's definition of a Type/ Class B.
"Commonly called van campers, Type B Motorhomes are built using automotive manufactured van or panel-truck shells"
This is the definition for a Class C.
"Type C Motorhomes are built on an automotive van frame with a wider body section attached to the original cab section." Also called a cut-away chassis.
Some manufactures call their 35' 3 slide Type/Class C a B+. So you see size is irrelevant to these manufactures, they consider anything without a cab over sleeper a B+.
Now I know some of you don't want to accept RIVA's (who sets the standards for the RV industry) definitions, and that's fine as it always seems to get people talking which is what a forum is for.
Ref. RIVA's consumer site
cjscotty wrote:
...we'll be trading in our B+ in a couple weeks for a B (on order).
BudJ wrote:cjscotty wrote:
As an owner of a B+, I can tell you they are technically a "form" of a C but very different. Do not let people tell you otherwise, it is very important for consumers. They have changed over the yrs with some being longer but technically they were made for people that wanted something slightly bigger than a regular B, and a little smaller or more streamline, lower in height with better gas mileage than a C. An easy way to tell the difference between a B+ and C is they do not have the large square overhang cab with the bunk. Nexxus is a great site where you can view the difference between their C and B+ as they clearly marked as such. Coachman makes a Prism 24 ft long 2150 (C) and a Prism 24J (B+) same floor plan. The 24J has no overhead bunk, is lower in height, has slightly less outdoor storage. I do not care for regular C's but really like B's and B's. They also get better gas mileage than regular C. Our B+ on a V10 got 12-13 mpg, a similar C same length would get about 8 mpg. The Leisure Travel Serenity, Unity, can be listed as "C's" but are a B+ form of a C. So is the Navion/View without the overhead bunk, Winnebago may call it a C, but many knowledgeable dealers will differentiate to help consumers. You can find some B+'s that are 30 ft long know or they made a few which blurred the lines. Whether people on here who don't even own one want to argue that they are C's, I will always fight this bc they are very different than a regular C for the above reason mentioned and that is important to consumers. Other example of a B+ is the Pleasureway Pursuit. Even tho the Pursuit can be bought with a VERY small bunk overhead as an option, it does not have the large square boxy like overhang cab over the front.
Well, with my 15 inch laptop, that is another 4 inches.
Bud
