Calisdad's avatar
Calisdad
Class C Alignment
I'm having our '94 Tioga (E350) aligned tomorrow.
Recently I've read here to ask for 5 degrees of camber. I'm not really sure what I should ask for and when I spoke to the salesman on the phone he said I should talk to the technician when I bring it in. Can some one please clarify? Is this out of the suggested settings?
I do have the previous left front as a spare now and when I roll it, it is clearly worn more on the inside, but for some reason not evenly.
thanks-
  • Explain to the technician that your unit has a tendency to wander and you have read on this forum where adjusting the CASTER to the upper end will resolve the issue. The Ford specified range is from +1.5 to +7.5 and you want the most you can get in this range..
    As stated, it is + CASTER not CAMBER that you want.
  • E450s like 5degrees. They just do. Mine is 5 and
    41/2. They will need to install the bushings to do it.
    Bob
