CharlesinGA wrote:
I think Alcoa does make an alloy inner wheel for the rear now. Used to be that you retained the steel rim on the inner rear. There are three part numbers, rear inner is not polished at all, outer rear is polished on the dished side, and the fronts are polished on the "bulged side". You cannot put the wheels in different positions due to the lack of polish on the inner side of whichever wheel it is, and the fact that the inner side gets marks, impressions and rust stains, etc, from the hubs.
Charles
I understand that if you install that inner Alcoa wheel, you will also need to replace all your rear wheel studs because they are too short to accommodate the extra thickness of two alloy wheels.
