We take our small-but-fully-loaded 24 foot Itasca Class C two-wheel drive offroad in the desert (in dry weather) all the time - albeit driving carefully and slowly when we do.
Here's some of my thoughts regarding our Class C as compared to a truck camper:
- It's on Ford's ton-and-a-quarter E450 chassis ... heavier duty than most of the common everyday truck campers ... including of course the dually ton chassis "350/3500" class pickups under many truck campers.
- Since a Class C coach structure is mounted right down onto the truck frame, the center of gravity of a properly built Class C can wind up lower than that of a truck camper. This is of course an advantage for off-highway use.
- Due to our small Class C being on this chassis ... we enjoy the ruggedness, added frame stiffness, and reliability of "chassis overkill". Chassis overkill provides such advantages as minimum chassis twist under the coach on rutted roads, more than adequate brakes, more than adequate engine/transmission cooling, and more than adequate towing/pulling power due to a low differential gear ratio. This low differential ratio is especially nice for very slow speed travel offroad without resorting to torque conversion (heat generation) within the transmission - as we sometimes travel at only 7-10 MPH in certain offroad settings.
- We can carry "any amount of added creature comforts we want", weight-wise, because the motorhome with full tanks is still over 2200 lbs. lighter than the chassis maximum. How many truck campers have a margin this high?
- Our water supply is 45 gallons. A lot of TC's don't have anywhere near this gallon capacity.
- Our grey water tank is 29 gallons, and it's contents can be off-loaded into the black water tank in case it fills faster than the black tank. A lot of TC's don't have anywhere near this gallon capacity in their grey water tank.
- Our black water tank is 39 gallons. A lot of TC's don't have anywhere near this gallon capacity.
- Our built-in propane tank capacity is 18 gallons. Most TC's don't have anywhere near this gallon capacity.
- Our shower roof has room to spare above my 6'2" frame. How many truck campers can provide this?
- Our air conditioner is adequate for any desert heat and can be powered by a built-in generator. How many truck campers are set up like this?
- Our black and grey water tanks are 12 volt heated for drycamping in cold weather. Keeping them warm via the propane furnace is not required.
- Our fresh water tank is contained within the coach interior so it cannot freeze in cold weather if the propane furnace is used during cold weather.
- We can get to the coach area from the cab without leaving the vehicle. How many truck campers can do this?
- Because of the above, when combined with our relative small coach area volume, the Ford cab air conditioning and heating can also handle the entire coach volume. This capability backs up the coach's more than adequate air conditioner and propane furnace.
- When we get to our campsite, we have two queen size beds and one full size bed available (we normally use both queen size beds for sleepiing). How many TC's have this?
- The main engine alternator has heavy cabling going to the coach batteries so these batteries can be charged up very quickly and fully when traveling or while only idling the main engine. Not all truck campers can do this.
- Our main built-in generator can power "every need, if required", so not even a propane system failure could cause us to have to abort a camping trip.
- Since the built-in generator draws from the main 55 gallon fuel tank, we could go a few days with no propane fuel and/or no sun (for solar). Only certain diesel TC's with diesel marine appliances fed from the main truck fuel tank can do this for any length of time.
- In addition to the partial list of advantages listed above, we of course also have the raw storage room for a whole bunch of safety, convenience, and backup reliability items that truck camper users can only dream of: Such as the room to carry along a portable generator to back up the built-in generator and the room to carry two full size lounge chairs, four regular chairs, an outside table, two chair side-tables, a full size shovel, an outside dog pen, fishing gear, a full power air compressor, a gas BBQ, a gas burner to backup the galley cooktop, an oven, a microwave, a well-stocked tool box, 100 feet of fresh water hose, 25 feet of sewer hose, etc., etc.. We carry all of this and more without attaching anything to the outside roof ladder, without piling anything into the shower enclosure, and without piling anything onto the beds when traveling.
If one was to combine all of the above in a small Class C with the addition of four wheel drive, then I would be hard put to ever prefer a truck camper over it.
Oh, BTW, I almost forgot a potential BIG ADVANTAGE of a small Class C over a truck camper: Way less number of steps to get up into it for some of us with bad knees and/or other leg or back issues!!!
