just4mrg's avatar
just4mrg
Class C charging
Just need to understand this a little more.
1) Plugged in to shore power, coach and house battery charging?
2) Engine running, coach and house battery charging?
If this is the case, what is this disconnect relay used for and when does this come into play to separate coach from house battery?
Thanks in advance. Lot of expertise here.
  • An excellent accessory that allows for charging of the chassis battery from the house batteries while hooked up to shore power or when running the generator is the Ultra Trik-L Start. Easy to install and not very expensive (<$50?).
    I am very pleased with my Trik-L Start purchase. Trik-L Start
  • A voltmeter will answer your questions, with much more reliability than any answers on here.
  • research BIRD - Bidirectional Isolator Relay Delay...the emergency start toggle lets coach battery and/or coach genset connect to chassis batt when BIRD keeps the batts separated if one gets too low
  • My C has a disconnect (manually turns the house battery circuit off when parked for storage) and an isolator (automatically keeps the house electrical system from drawing any power out of the engine battery when the engine is not running).
    When plugged in, only my house battery charges.
    When the engine runs, it charges both the engine battery and the house batteries.
    Your system and number of batteries may vary.
