mrmomb
Nov 15, 2016Explorer
garyhaupt wrote:
Yes..they all leak..but, so do all houses if they are not looked after.
One of the things to look for then, is a C manufactured using metal framing as opposed to wood. It's the repairing of the rotted wood framing that will cost the HUGE dollars. With a metal framed unit, you repair the leak, tear out the interior wall replace the insulation and put the wall back up. No rot to contend with.
As for leaks...the clearance lights and the seams around the cap are the biggest culprits. DO NOT buy a C with a fabulous front window in the cap. Then the windows. Those can all be removed and re caulked by yourself or a shop. Then the roof itself can leak. Any place on the roof where it has got stuff into it..thru it...the A/C housing. TV and Sat cables. Vents..are all areas to check, but...again..they all leak sometime. Getting it repaired is always the key.
Gary Haupt
Excellent post!! Kudos. Well written. I agree with all your points.
I do have a squared off leak prone cab over. Routine inspections and protective eternabond tape are my preventative measures.
38,779 PostsLatest Activity: Jun 16, 2026
