What is 11,030 ? is that your gvwr ? If so, your rv is basically the same as mine only you have the extra weight of 2 slides . Each slide is maybe 300-400#.
If that's the case it might not leave too much for your personal gear.
I'm not up on the Sprinters but I think it has been mentioned here about the shy payload of the Sprinter chassis being restrictive. Watch the rear axle rating as well.
Specs for 2018 Thor Motor Coach - Four Winds Sprinter Floorplan: 24FS (Class C)
Price. $111,300. $111,300. ...
Engine. Mercedes-Benz / V6. Mercedes-Benz Sprinter. ...
Transmission. 5 Speed Automatic.
Driveline.
Dimensions. 24.67 ft. (296 in.) ...
Weight. Towing Capacity. 11,030 lbs.
Capacities. 26.4 gal. Storage Capacity. ...
Holding Tanks. 30.0 gal.
