marty1300's avatar
marty1300
Class C steering stabilizer
Hello,
Inquiring as to what brand of steering stabilizer most choose. I see the two most common are by Roadmaster and Safe-T-Plus. We are getting a new Rv on the E450, chassis length is 31 feet
Thanks Marty
  • Harvard knows what he's talking about and I appreciate the advice he has provided about the caster adjustment in earlier posts. The "correct" alignment made a huge improvement in the handling of my new MW 31K. Better sway bars in the front and rear not only greatly improved handling but also stabilize the movement in the coach while parked. I don't feel I have a need for a new stabilizer bar, and I just completed my second 4000 mile trip.
  • Research E450 caster alignment before investing in steering stabilizers.
  • Any quality new Class C should need absolutely nothing right off of the showroom floor with the possible exception of proper tire inflation and perhaps an alignment... both of which are the dealers fresponsibility. If it needs anything else it is the wrong Class C... keep shopping.
    Think of it this way, would you spend $100,000 or likely much more on a nice Mercedes, BMW or Range Rover SUV if the salesman said "Well it will need a couple of thousand dollars worth of suspension improvements, an alignment and the tires need to be properly inflated"??? :S
    A serious, think 1 hour minimum test ride in a wide variety of road conditions to include some freeway time {see how it responds to passing trucks and how much fun merging is or isn't} should be a nonnegotiable condition of sale. If after making your best deal the dealer balks at the test drive Run Forrest Run! Go find a dealer who is willing to earn your business.
    As always... Opinions and YMMV.
    :C
  • marty1300 wrote:
    Hello,
    Thanks Marty
    All they are is a "return to center" set of helper springs that don't "stabilize" anything. I wouldn't waste my time or money on them. They're a gimmick, like those stovepipe things for your generator exhaust.
    Just pay attention to where you're aiming the rig, with the factory steering, and you'll be fine.
  • Hi Marty,
    Class-Cs that benefit most from a heavy duty steering stabilizer, are shorter rigs. Your rig being 31 feet long, will still benefit, but the problem is less prominent to begin with, especially if your wheel base is longer than average (for your length) and your rear overhang is less than average.
    With that said, our short under-24 class B+ has a Safe-T-Plus and it is effective. I cannot speak of other lower priced options.
    Two negatives for our Safe-T-Plus are...
    1) high purchase price
    2) no life-time warranty (just a one year warranty)
