rockhillmanor wrote:
I just think I would have felt better dishing out all that money to replace my converter if I would have seen a ripped up piece of metal. :W
I feel you, Brother! I fully understand that a plastic might not waste away from corrosion, like plastic vs. aluminum in salt water. If the quotes you sent are true, that the plastic part can be made in one shot where metal calls for forming, joining, machining, etc. then I'm down to one objection: I have seen simply too many cases where plastic has what I'll call a "chemical service life." Namely, the plastic and/or whatever holds it together deteriorates with Heat, Sunlight, Chemical Exposure, and maybe simply TIME. Absent something actually attacking it, like salt corrosion, metals don't display much of that.
We took a ride on this railroad
 and it's Narrow Gauge, less than the 4' 8-1/2" standard by about 25%. We talked about why Narrow Gauge was used. There's talk about tighter turning radius, but the guide said:
"There are three reasons why they built narrow gauge:
1. It's cheaper
2. It's cheaper
3. It's cheaper"
I rest my case.
