Middle_Fork_Min's avatar
Nov 27, 2014
Doea anybody know about chipping a 92 bronco for"tow mode"
What I have is a 92 full size Bronco...somebody said I could get a chip to plug in so it would throw the transmission/transfer case into a "tow mode" with the transfer case in neutral....does such a chip exist??? I've searched, but can't find such a beast....
  • poncho62 wrote:
    I was kind of wondering about this too....I have a GMC pickup, with push button electronics doing the shifter of the 4 wheel drive. There is no neutral button. All my older 4x4s had the lever with a neutral.
    Check your manual. There is a sequence you have to go through to put the transfer case into true neutral.
  • I had several full size Broncos over the years. As I remember the major difference between the late 1980's models and the later ones was that the earlier ones had manual front wheel drive hubs.
    To shift to 4 wheel drive in my 1987 full size Bronco I had to first get out and manually lock the front hubs into the drive position. Once that was complete I could shift the transfer case into either high or low range 4 wheel drive using the lever on the floor.
    My 1995 had electric hubs on the front wheels that eliminated the need to get out and manually lock or unlock them. The axles had finer splines than the older manual locking ones and would fail from time to time. At the time Ford made a replacement manual locking assembly that could be used to replace the electric locks.
    I doubt Ford still make those kits available, but any good 4 wheel drive shop should be able to advise you as to whether your front axle can be converted and supply parts if it can be done. The axles were from the Dana Corporation and used in many different 4 wheel drive applications of that era.
    The other thing to ask the shop is whether when putting the transfer case in neutral is all that's needed to disconnect the rear axle from the transmission. In some models there's enough of a fluid connection remaining (even when the transfer case is in neutral) that the drive shaft will still spin slowly. There may not be enough lubrication within the transfer case and transmission to keep the bearings properly lubricated.
  • Ford did have electric shift back then; I had it in an '86. I believe at one time you could get a modification from Ford to enable a neutral position. Whether that support for older models is still available... doubtful but you could ask Ford.
    I read some accounts that you could remove the electric shift motor and manually shift the Tcase into neutral, or replace the electric shift with a manual lever control.
  • My Suzuki has an electric shift but does have a neutral button.
    I don't remember when Ford changed to electric but I thought it was in the late 90s about the time the explorer came out.
  • I was kind of wondering about this too....I have a GMC pickup, with push button electronics doing the shifter of the 4 wheel drive. There is no neutral button. All my older 4x4s had the lever with a neutral.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
