squirtdog's avatar
squirtdog
Class C towing
Looking around for a Class C that will tow 6000lbs(jeep and trailer) Any suggestions? Model? Trying to keep the length to about 25-26 ft. Thanks-Don
  • ed6713 wrote:
    I don't think there is an E-450 chassis out there that can safely drag more than 5,000# around.
    It's probably not the E450 chassis per se with it's 4:56 rear differential, large diameter driveshaft, and 5-speed (6 speeds internal) transmission ... as delivered by Ford that presents the problems.
    The problems are more likely the sturdiness and length of the frame extensions that Class C motorhome manufacturers weld onto the Ford OEM frame ... plus the issue that many Class C motorhome owners have with a truck engine that is designed for, and requires, high RPM travel up grades in order to tap the necessary (V10's) horsepower. ;)
  • With that kind of weight I would go with a Super C diesel. Any kind of grade will have a gasser screaming at red line. I'm pulling 3200 lbs and that V10 is earning its pay on the mountain passes here in Nevada. Can't imagine nearly doubling the tow weight.
  • do you have to tow the jeep on a trailer ? Perhaps you should consider a "race" coach (more commonly referred to as a "truck conversion"...youll have a better transmission (up to 13 speed - automatic) and more HP (450-650) and a towing capacity of up to 40000 lbs.
    Thor is then next consideration - built on a F550 and capable of TOWING 10,000
  • pianotuna wrote:
    Lazydaze is worth consideration.
    4,000# max. tow capacity.
    I don't think there is an E-450 chassis out there that can safely drag more than 5,00# around.
  • Unless you move up to a Super C you will find most C's towing capacity limited to 5,000# or less. This includes the 30 - 32 footers as well.
    :C
