Hi All, I have a Class C that I am trying to remove the tv. It is on the side next to refer. It is mounted on a swivel, is there something that needs to be unscrewed to release tv? Thanks.
If you swivel the turntable thingy one way or the other, are there screws or plugs visible underneath it that hold the TV down?
If not, one other possibility I can think of offhand is that the front trim strip also locks the TV in place; it would be removed by prying out the wooden plugs and removing the screws presumably hidden underneath.
If all else fails possibly removing the microwave (?) underneath the TV will allow you to unscrew the entire swivel mechanism from below.
