GilONel wrote:
I pulled my Class C ( 2008 Jayco Greyhawk 31SS) out of the driveway yesterday (Sept 14th) to take it over to the mechanic for its final check before we head to Pigeon Forge Tennessee.
Anyways to the point.
My RV sits slightly downwards and when I pulled out I was christened with an amount of water inside the Rv. This was disconcerting as I looked around on the roof and at the front nose cone (or whatever you call it) and there were no obvious cracks in the caulking.
The water flowed from the front inside the nose cone over the area where the bed is right above my head. Any ideas on how to find this leak or what to do. We had just finished a downpour for a few hours the day before. ....
Thanks for any ideas and help.Gil
If you have side windows in the cab over the water is coming from the windows because the weep holes in the frame are plugged.
With a heavy rain the window track fills up and leaks inside if the weep hole is plugged up. AC condensation draining over the RV side will also cause the same leaking if weep holes are plugged.
Check the weep holes and clean them out.
