- Tom_BarbExplorer II
Dennis M M wrote:
Make sure you pull the fuse for the FF before you stick your fingers in there!
There is an OFF switch. be sure it is in the OFF position. - oldchief7155ExplorerYou can buy the pop on screens at camping world too.
- Dennis_M_MExplorerMake sure you pull the fuse for the FF before you stick your fingers in there!
- SCVJeffExplorerBTW- Fantastic Fan sells replacement screens that snap into place... No screws, making it a lifeless easier for spur of the moment cleaning binges..
- LynnandCarolExplorer
IAMICHABOD wrote:
Here is a hint from Fantastic Fan, after it is dry, wipe it down with a little 303 protectant, buff to a high gloss, it will minimize the amount of dust and dirt build up.
I will try this. Thanks for the hint!! - IAMICHABODExplorer IIIJust remove the screen by twisting it or removing the screws depending which model you have, then use a paper towel with some Windex or Simple Green on it and wipe down the blades and get the grease off, wash the screen and pop back in place.
38,782 PostsLatest Activity: Sep 02, 2026
