ct78barnes's avatar
ct78barnes
Cleaning my lines for spring
I did like I always do and flushed the lines Then I put in a tank of bleach treated water and then set a few hrs and ran the lines to get the bleach water out I ran it till it was empty and replaced with fresh water. I turned my by pass to fill the water heater. when running the water there was a lot of air in the lines.it took a while but all are working fine but the sink in the bathroom. It started to sputter but lots all pressure and the out side show was the same way and the shower head is below the sink.I wonder if there is still a air bubble in the lines. It works but just a trickle of water comes out. Any ideas or help would be great I have a 2011 Winnebago .
Thank for this great site.
  • Where are the shower valves located and what are lift handles . I am thinking the aerator is the filter on the Faucet at the end of it . Thanks for all these quick replies.
  • Also if you have lift handles ours some times after bring back on line do not lift and no water.
  • Check the aerator at the faucet for scale/dirt buildup blocking the flow.
  • Check the outside shower valves and make sure they're turned off.
