turbojimmy
Aug 31, 2015Explorer
Cleaning out a cast iron block
This is my second season with my '84 Allegro. Bought it with a blown engine. Put a Craigslist-found 454 in it (truck spec GM Performance crate engine). When I got the engine home, put it on a stand and turned it upside down a bunch of rusty water came out of it. An alarming amount actually.
With the water pump off of it I ran water through it until it came out clean. Last year was the first camping season with it. It ran great, though on the warm side.
This year, on my last trip out, it overheated pretty bad. I could not get it to cool down.
Yanked the radiator and brought it to a local shop to be rebuilt. For a significant sum of money, I'm getting an all-new radiator custom built. The rad shop called me today and said my problem was that there was a baseball-sized chunk of rust clogging the inlet side of the radiator. The radiator was toast anyway, but they advised me to figure out why this happened otherwise the new radiator will meet the same fate.
So - I need to clean the block out some how. On the one hand I'd like to think the many heat cycles have dislodged most of the rust in there. Upon removing the radiator the lower hose drained clean. I took the thermostat housing off and hosed out the engine - came out clean too. But how can I be sure?
The radiator guy suggested yanking out the drain plugs and seeing whats in there. He suggested pulling out the freeze plugs too.
So....does anyone have any advice that's different than this? Ideas would be appreciated.
